old turbo setup to my new turbo
dsm91TalonTSi
62
May 29, 2006
Burgettstown, Pennsylvania
Hello, i had the evo3 16g turbo for my 1g, and it came with the elbow for the pressure source to the boost controler, however the my new turbo doesnt have the fitting to connect the elbow or a way to run the line for the pressure source, wot should i do? any thoughts or comments? Below is a picture of my new turbo above me old evo3 turbo.<br>
what elbow are you talking about? take a picture of the fitting on the old turbo so we know what you are talking about. Thanks
I believe he is referring to the j-pipe, and the nipple on the stock one. Tap into the compressor housing or as close to the outlet as you can. The 90* bend on your new turbo's compressor housing would be a good spot, or the flat spot where the serial number is at.
Yea if that is what you are talking about I had the same thing, I just took the nipple off my t25 and tapped into where the serial numbers were on my t3/t4 and it works great!
