Oil source for a green
EvoSix
100
Aug 6, 2002
I jus got my fp green to replace my busted bullseye 50 trim. The bullseye gave way because i was running the oil feed of the filter housing with no balancer shafts without the oil restrictor. Is it safe to feed oil from the filter housing to the green?
It depends on how much oil pressure you are seeing at the turbo. With no balance shafts and without porting the oil pressure relief valve, your oil pressure could over 100 psi by 3000 rpm's. The safest thing to do is contact Forced Performance and ask them what the acceptable range of oil pressure is. Most likely if you damaged your Bullseyes turbo the same thing would happen to the Green.
