oil pump problem maybe?
upgrayedd
Sep 2, 2009
union mills, Indiana
i have just recently sold my TSi, and purchased a 95 eclipse GSX AT and it has a problem, here i go;
when you start the car, it runs good, no engine noise or any of that, but after it runs for a little bit, itll start knocking, misfiring, and running like complete shit. and then it dies and wont start back up for a while.. the engine my friend put in it was used, but it came from a running car and sat for a bit. is it the oil pump? or could it need primed maybe? thanks in advance
I don't think the oil pump will cause you all of those problems
Did you mean Fuel pump?
I recentrly had problems with the oil pump myself and the problems related to that would be whine noise especially about 3-4k rpm's, no oil pressure if you didn't prime it, or if it's not properly put together. Make sure there is oil pressure when the engine is running or you are going to kill your engine...
but the fuel pump was good when the previous engine was in it. what would make this any different?
Easy way to check it out is to take off your oil filter and cut it open..if you see metal then you know where the knocking is coming from.
we don't know what exactly you put on the car with the new (replacement) engine, did you use the same spark plugs, cables, coils, Power Transistor Unit that came with the replacement engine?
If you did, try swaping out these one by one with the ones that your car had before the swap to see if you solve the problem.....:thumb:
just doesnt seem like a spark issue is all, nor fuel. but ill try it i guess.
You can also check your cam angle sensor. Its starting at first so the timing should be ok, but if its dying and then wont start for a while, sometimes that can be a bad cam angle sensor. Mine had a very similar problem. I do agree checking your oil pan too.
thanks guys ill try all of these and get back.
changed a bunch of shit, and it still does it.
found out_+_+... when the engine revs past 4k rpms, it starts knocking and missing. other than that it runs okay
oh, and there is a huge dent in the oil pan, by the drain plug.
the girl my friend sold it to prior to me hit a "rabbit" as she says, i think rabbit is code name for "rock slash boulder" it goes into the oil pan, and its on its way off. is that the issue do you think?
if anyone feels like helpin me out, you can text me. 219-575-4675
umm, a couple things i agree with the code name LOL.... but another thing is did you drop the pan at all to check for metal shavings? does it make a clank sound right when you turn it over and then when you rev to 4 grand it starts to knock and miss time? and if its missing time then you obviously have some bent valves... your going to have to pull the head to check... if there is anything else to add just tell me and ill do my best to help
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
