Oil pump gasket????
tbird
170
Nov 10, 2002
Havr front case apart... just did balance shaft delete and putting back together... I have a whole bottem end gasket kit and dont see one for the oil pump...... does it use one? im not tlaking about the filter housing I have that gasket ...
For which part. If you read the VFAQ you'd know that there is a gasket for the filter housing and the front case to block. No gasket between the front case and pump cover.
From the VFAQ: http://www.vfaq.com/mods/balance-shafts.html
You may also need a oil pickup gasket that isn't listed in the VFAQ. It looks like Tom left his attached to the pump but yours might not survive.
Steve
Yeah i looked over it and the chiltons manual... was just making sure before I bolted it all back up thanks
Try not to scratch it, in most cases a very good finish is better than any gasket, such is the case in many pumps and pipelines that use ceramic seals.
