oil pressure sending unit
eclipse2gnt95
Banned Member
40
Jul 21, 2004
lusby, Maryland
HELP PLEASE i am about to have the stage 1 hahn race craft installed but i cant get the oil pressure sending unit off does any one know if it takes a special tool or special socket its a 95 gs please help
I bought a gauge for that like a month again and i couldnt get the old one out ether, where it is at, its to hard to get at. I found the socket size for it but i can seam to get in there to get levrig.
I just installed a hahn stage 2 kit on my car, and i had trouble removing the pressure sender unit as well. It was an easy fix however...all you have to do is go to a local car store and get an oil pressure sender socket. It is like some special 12 point socket or something, like 8 bucks.
i got her off thanks alot i just stopped buy auto zone grabbed the socket and popped her wright off
!! were is the oil feed line, i cant find it i know its under the throttle body in that area, anyone got a pic !!! or more information on how to locate it thanks
right by the trasmission housing where it bolts to the motor its a silver nut half silver then turnning to black plastic and then plugs into a seperate wire thats the oil pressure sending unit plug well right next to that like 1 inch over is the line and the fitting
do you still need the information on the oil feed line i have the information and can help you with it. Write back if help is needed.
