Oil pressure light
clipse-T
111
Feb 6, 2006
Tyler, Texas
Well my oil pressure light was flickering as i drove, i thought it was the oil pressure sending unit so i replaced it..now its on but it is solid, and i do have enough oil in there. Am about to install a oil pressure gauge and see if my pressure its ok. If it is, what else could make it from flickering..now to being solid? Any help is appreciated!
make sure the sensor wire is actually connected, if it is clean it with some lectra clean or contact cleaner, my 2G had the same problem and it turned out just to be the wire was cruded up.
Yeah, the wires to the plug get contaminated very easily. Try to clean them as previously stated and let the connector dry real well then put a small peice of electrical tape around the seam of the connector. Should prevent any debris from re-entering / leaking into that plug again. Post an update to let us know if the problem is still there. :thumb:
