Oil out the breather
Shogunstang
Feb 27, 2006
Niceville, Florida
I have oil coming out my breather on the side of the head. I brought it to the mechanic and they raised the breather 2 inches and said that would fix it. im only running 15 psi should this be happening?
The height of your filter has absolutely nothing to do with it. The oil you are getting is normal. I am assuming you replaced the stock line to your intake with a small filter. To do this properly you need to add an oil catch can. Search the forums, there are tons of articles about this that will help.:dsm:
Check your PCV. Cheap to replace if it is sticking.
