Oil light coming on.
need4speed187
May 10, 2006
salem, Massachusetts
The other day i was driving and noticed my oil light flickering so i let my car cool down a little bit then then check it it was right in the middle of the max and min. It now doesnt come on until about 1 min after i start my car then it comes on and stays on. Oil pressure guage reading fine, what do u think is causing this? Also I have my hallman mbc set at 15psi but it reaches it quickly then drops off to about 12-13psi. possible boost leak? or boost spike? any help would b appreciated.
Could you fill out your car profile by the way? There may be a problem with the sending unit. Did you check the connection to it?
