oil leaking off trans/transfer case
volcomsnow245
492
May 4, 2011
chicago, Illinois
Hey guys it's seems there is a small amount of engine oil that leaks off the transmission/ transfer case area after the car sits all night the next time I leave I see it on the driveway any ideas where this could be coming from I can't find it. Thanks
Check your Axle Seal, which is on top of the T-Case.
When it leaks, It is hard to figure it out (some times).
Because being close to the T-case Seal and the Tranny Shaft Seal, it gets tricky to figure it out.
I would say that is your Axle seal.
Check from your Driver side to see if it is the Axle seal, you can be able to see it over the T-Case.
