oil leak from downpipe
cds1320
113
Jan 1, 2008
east syracuse, New York
ok so i searched and couldnt find anything. i have a 4g63 with a hahn super 20G which has a t3 flange so instead of using an adapter I bought an obx t3 tubular manifold with an external wastegate. I also upgraded to 680cc injectors any way i have an oil leak coming from my exhaust. its smoking out the rear end and out of the hole i have in the down pipe and its dripping out of there too any suggestions on why its leaking bad seal or gasket or something? i dont know, help would be appreciated.
Have you checked the exahust mani studs if one is loose it could drip a bit.Otherwise i would say the turbo is blown bad seals.
i checked the gaskets they are all fine on the manifold im missing the far bottom right bolt but nothing seems to leak out of there the leak looks more like its coming from the turbo area but the turbo isnt old
it seems to be leaking from where the air filter piping connects to the turbo. does that mean that my turbo is bad?
ok i found it and fixed it it was the line from the oilpan to the turbo was kinked and cracked
