Oil leak from Balance Sprocket?
2gTSIFZone
108
Jun 24, 2010
Riverside, California
As stated i just finished rebuilding my motor with a new to me block... now when it turns on there is a oil leak from BEHIND the balance/r sprocket... my mechanic said he tried replacing the seal to no avail... He started saying that it could be the bushing on the other side... Curious if this theory holds weight. Read on another thread to use high temp sealant, but the picture provided was on the bolt itself... and im pretty sure its leaking from behind the sprocket... and ideas?
95 Talon TSI AWD
anyone have any ideas? Its coming from behind the balance/balancer belt sprocket... could really use some ideas... thanks
solved, there was a crack/fracture in the timing cover... just my luck... though fixable just kinda bummed that its yet another wrench thrown in the mix... everything comes in cycles though :D ordered the new cover along with gaskets, should be in within a week... keep yall posted
