oil filter housing leaking; which one!!!
jongraack
154
Jul 14, 2011
Saint Joseph, Michigan
Just curious if I should stick with the oem housing, or is there something better to use that bolts right up? Not sure if I will be running any oil feeds from there or not.
You can use the evo 3, 8 and 9 OFH if you want to upgrade to an external cooler. Otherwise stock works fine for most.
Nobody recommends any other styles? How about forward facing? Should I think about using an adapter in case I want to run any oil lines for the turbo or is that not needed?
I've heard of people using FF style, never used one myself but I would personally rather use the EVO 8 housing because it points the filter straight down and it's a lot easier to access and change.
Anyone know a good place to get an OEM housing? Looking for somewhere that people have had good experiences with.
