oneslowwdsm
- 858
- 124
- Mar 30, 2009
Spring,
Texas
Simple question: could a clogged oil filter cause low oil pressure?
My oil pressure is going down to "L" and sits there and then shoots back up to normal while cruising. This happens a few times while driving. I'm thinking it may be just a bad sender but I did just replace my oil pan and this is when it started happening. Could it be possible some RTV got stuck in the filter or pump causing problems? The car runs fine even when it is low. No dummy light either.
