dboyle23
- 297
- 16
- Jun 10, 2010
Chicago,
Illinois
hey guys, trying to finish tuning my car since I got a new fuel pump.
FIC 750's, 16g, dw300 pump, tuning with evoscan/ecuflash.
Been having a problem tuning. No matter the settings I am running lean. So, using evoscan I used the actuator to turn off each injector. 1-3 cause the car to stumble terribly, injector 4 only stumbles a very slight amount. So, obviously there is a problem there.
I changed the plug, no help. I swapped two of the plug wires, no change. The only other things it could be would be either a leaking injector or a clog, correct?
Any other ideas?
Any other ideas?
