Oil Feed Relocation question
spectr019
254
Oct 28, 2004
East Lansing, Michigan
I've found some pictures of it when I wasn't looking for it, but of course now that I need it, I can't find any pictures of where the SS oil line for a turbo swap is to be connected. It looks like the stock line is right at the oil filter, but on the bottom side of the filter housing there is a bolt closing up what I'm assuming to be a hole, but it just seems so close to the stock line location that it wouldn't make much of a difference. Could anyone please send me a picture of where it is to be relocated? Thanks
Ben :talon:
okay thanks a lot for the picture. Last question, what is the line directly above the oil feed line on the filter? Mine sorta broke when I was getting the stock oil feed line off...
That wire that I think you're referring to looks like the oil pressure sending unit wire. In my experience, that plastic clip falls off very easily, and when it does, I get the oil pressure idiot light.
excuse me for the O/T post, but blcknspoolin, ive noticed i dont have that line in the yellow on my engine, is that a bad thing?
mr boxx is correct. if it breaks/falls off, your ECU will see now oil pressure and will not display as such.
99GSX- the factory coolant line extends from the thermostat housing to the oil filter housing. it is a hard metal line, not the fuel line like I have it as. I had to remove and replace mine, that is why it is like that.
