KeelesKustome
- 882
- 17
- Dec 29, 2007
Waverly,
Tennessee
Well, i have my 6 bolt swapped into my 98 gsx, with the auto kiggly kit yadayada.
I was told by a well respected member i baught this engine from that the balance shafts were deleted and it has 2g pistons, front facing oil filter etc....
they are obviously deleted. rather the shafts are removed i am unsure, I've noticed since i got the car running the oil pressure stays rather low unless eccelerating and then it goes where it should be till you drop back down to an idle.
well long story short i have been watching it closely, and bam today all my preasure gone! instantly oil everywhere all over timing belt side of engine, pulled the cover off and wow what a mess.
I am unsure at the moment where the leak came from and it seems that my valve cover gasket is not the cultprit, neither is the oil filter..
best case scenerio would be......?
and worst case scenario would be.........?
I'm disgusted with this right now.
