Offset question
92_4g63
Sep 22, 2004
Williamsburg, Virginia
Just to make sure I have this right if I have rims with a +50mm offset and stock is +46mm, if I put a 4mm or 5/32" spacer it will make the rims have the correct offset?
I know this seem easy enough but just want to make sure because 4mm seem to be a small spacer. Also 5mm seem to be very easy to find as opposed to the 4mm, How big of a difference will a +45mm offset be?
Yes a 4mm spacer will decrease total wheel offset from 50 to 46mm. It will also make your lug studs 4mm too short. Why bother. Are your tires rubbing?
The rim will rub the strut according to others that have these rims.
