oem slave cylinder length when extended
stud3737
70
Jun 26, 2013
Valley city, North Dakota
Does anyone know how much your slave cylinder rod pushes out? Have clutch drag but car goes into gear no problem. I kind of want to make sure it's the slave before I spend 60$ on one. My travel is about 7/8 inch full travel when I push my clutch in (how much the rod moves)
To me that seems fairly short but I'm wondering if anyone else knows
Backround:
new 2100 clutch with sprung street disc
New flywheel, everything torqued to spec
New TOB
Clutch forked looked fine
The drag happens at about 6300 rpm. Pedal assembly is fine, system is blead, and master cylinder is not leaking
I think it should drag before 6300 rpm, that's kind of high. Make sure your on a flat and even surface with the e-brake down and your foot of the brake. It could also roll just a little with the engine revving that high.
I did as jacks transmission suggested and how jafro does on YouTube... you can smell clutch when it does it too :/
