Odd noise before stopping??
Joe DSM
41
Jul 20, 2014
highland, New York
whats up guys I'm having an odd issue with my 98 gsx. My breaks work great but right before my car comes to a stop I'll hear a crunching sound? I replaced all 4 breaks and rotors and it still happens. The noise isn't consistent it goes on and off kind of like a warped rotor sounds like. It happens when it hits a sertaint spot on my rotor then stops for a second and comes back. It only happens right before my cars going to stop but I have no clue what it is!
Did you check the front end for loose or worn components ? Balljoints, strut mounts etc. Bounce the front end up and down or have a friend do it while you listen for noise. Also you could drive and have someone walk right next to the car while you stop to get an idea where the noise is.
Have you done any brake upgrades? I mean like cross drilled rotors or anything. I have for that the rotors on mine will make a similar sound and mine are all upgraded
  • Wanted 6 bolt NT water pipe
    • chrisman287
