Odd idle
95DsmTsiauto
119
4
Aug 6, 2005
Irwin, Pennsylvania
I just installed a new t-stat because my upper rad hose kept getting bloated and now my idle changes. After driving my car if i come to a stop or put my car in park my idle will be like 1000-2000 rpms.. If i give the car gas my idle goes back down to the norml 650-750. ANy help here would be appreciated. All i did was change my t-stat. It was fine before.
Log your coolant temp and tps, those two will help determine the problem further.
What T-stat did you put in? Is it a really low temp opener?
You could have a malfunctioning FIAV but I doubt it.
You could have a malfunctioning ISC but I also doubt it.
My guess is your throttlebody needs adjustment or the cables need lube.
Ok. I dont know a lot about cars but i did know i had to burp it. WHen i had to stop burping i didnt know. I just let my car idle for like 15 minutes with the rad cap off. It just kept letting air out. I got sick of sitting there so i just put the cap back on. I used whatever t-stat was available at advance auto. It was around 15 dollars. i still have the box i will check it when i get home from work. when i stopped burping there wasnt any air coming out.. so i figured it was good. As for the throttle body needing adjusted. I dont understand why it would if it was fine before i changed my tstat. THe only thing that happened was drained my coolant and put 50/50 back in. Also my upper rad hose is still getting bloated. Cant seem to figure that out.
Well its fixed now. I have always had an exhaust leak on the downpipe to the the catback and when i would pop my hood i heard it. It got the point i was losing power. GO figure that my xs power exhaust manifold cracked after 7 months on my car and only had a t25 on. Last time i buy that crap.
