obd2 codes is this bad?
tsiboost14
36
Oct 24, 2012
Newport, Pennsylvania
Hello dsmtuners members my names joe and i have a 97 eagle talon tsi awd and i hooked up my obd2 reader this evening and it threw me 2 codes one is (is0941) and the other is (kwp2000) the first one has to do with the fuel i think and the second says i have a bad wastegate. please respond below if you can help me figure out exactly whats going on and how costly it will be to get fixed. please and thanks. :rocks:
Neither KWP2000 nor ISO are trouble codes.
What scanner are you using? And what reason do you have to believe you are having fuel and wastegate issues?
Is the car giving you any symptoms to make you think something is actually wrong? I would use a handheld scanner to clear the codes out, then drive the car a full cycle and see if the CE light comes back on.
the one code is for the wastegate actuator. the other is for something with my fuel system i forget exactly. and i did use a hand held scanner. and i cleared the codes and the light came right back on when i started the car. i dont really notice anything except for boost lag and i am burning very rich
