obd1 cel check fail
spooled_4g
Jan 18, 2010
Fort wayne, Indiana
hola i have a 92 gst 6bolt. i just replaced the clutch and pressure plate because my clutch disk springs exploded out. well now i got it back together and it throws a cel (check engine light). now i know how to check it, with a 0-12v meter but, i tried to check it and it says zero. now before you say it NO oriellys,advanced or autozone dont check obd1 cars i checked all three. now i know #1 pin is hot wire and #12 is ground so idk whats wrong. yes the ignition was on and i even tried it while it was running. so im out of ideas all fuseses and relays are good. Now i became aware of a ground wire i riped out while i was laying on the floor i noticed it, it goes to the steering colum and bolts to the plate that surrounds it. WTF does that ground go to, thanks for your help ahead of time
:barf:
