Coup D E'Tat
- 1,960
- 8
- Dec 22, 2002
Pittsburgh,
Pennsylvania
Hey, after getting my car back together, I forgot that I left the first O2 sensor unplugged at the connector (it wasn't removed from the O2 housing,) after seeing this, I plugged it back in with the car running.
Before I plugged it back in, I was getting a CEL saying the 2nd O2 sensor was bad, and now, after reconnecting my exhaust (was running open downpipe cut before cat., now running a cutout) I'm getting the code P0125.
There is plenty of coolant, and according to the factory temp. gauge, the car gets/stays warm. I changed the thermostat a few months back, so I doubt that is the problem. The other possible fix as listed in a code handbook is to change the engine's coolant temp. sensor (I believe that's what it was, in the handbook.)
After looking more into it, I read that this code is also sometimes thrown by bad O2 sensors. Now, would the first one be bad since I plugged it back in with the car running? Would the 2nd one be bad for any reason? My car has been down for a little while, and needs inspected, and until I get this figured out, I can't drive it
Thanks in advance.
Thanks in advance.
