O2 Housing / Dump Pipe with a waste gate welded on
4g63turbo84
614
Dec 10, 2008
ocala, Florida
Weld the wastegate where? If you have a friend that can reinforce things... why not get the other wastegate that is already made for an external wastegate :confused:
I'm going to be using a holset turbo so i will need a external wastegate set up and the dump pipe is the best place when you got to a external set up
Oh, you want the BEST... then why not just buy a good one that has the external wastegate mounted already? I can't hear my dump pipe over my exhaust anyway. Might save you some hassle.
Do you already have the turbo? And it's set up for you to run the wastegate on the o2? Mine was set up for the o2 but I made this so I could run it on the exhaust manifold.
Scm6152e - DSMtuners Gallery
