o2 eliminator and 02 sensor.
AWDfrank
242
Jun 1, 2005
Bakersfield, California
Will putting an 02 eliminator while using the stock o2 sensor be a problem? Will my stock internal wastegate be ok to use while still having an external dump o2 housing. Im planning on using the 3"eliminator with a 2.5 inch downpipe and stock cat and catback, do you think this will be quite while driving normal (i had open downpipe but i got a ticket other day)? Thanks a lot.
Your o2 sensor will be fine in the new eliminator and your stock wastegate will be ok on external dump housing. Now as for sound it should be pretty quiet while normal driving since it still has a stock muffler and cat. Your wastegate will be much louder when you hit your boost setting since it is open to the atmosphere, but i'm sure you knew that. I know it will be more practical than running an open downpipe everyday. just my opinion though
yeah the 02 eliminator is good, a pain to get the dp off sometimes though. I have a used rnr o2 eliminator, 2.5" turbo back if you want to buy it. pm me
No, i currently have an o2 eliminator and dump tube and the car runs perfectly fine no problems at all. the internal gate will be fine and you wont reak it unless its weak, your going to have a loud dump when you hit your boost setting. It will be about as loud as your open down pipe
