o2 dump question
AWD_Boosted4g63
115
Sep 2, 2007
Houston, Texas
Probably the best way to check is to take a ruler and hold it against the stock one. I'd say the dump tube is about 4-5 inches. I'd also say it sticks out about 1.5-1.75. Just some rough figures.
It should fit fine,you might find out that the dump pipe is too short and will end up lengthening it.Plus the angle its at is pointed right at the slave cylinder.Just some things i have noticed with dump 02's.
Have you had any trouble with it dumping right on the alternator? I heard that it could burn up your alternator, because of the hot exhaust
I wouldn't get it. If he as a 1g and has a 3inch exhasut, most likely he will have problems bolting it on because the flange that mates with the down pipe is much too angled. On 1gs the cross member is behind the radiator. Meaning that the dump tube will dump on top of the cross member and not exit to the atmosphere. Well, it can be helped if you guys are willing to modified it. Make the dump tube longer and dump safetly to the atmosphere, make the actual housing tube form turbo flange to dp flange a bit longer and reduce the angle a bit.
The ebay dump tube does clear the alternator. I think all of dump o2 housings do. But on a 1g, again they will dump right on the cross member and will make a mess leaveing everything dirty. I personally have the SLS o2 dump and really like it. It goes around infront of the dp and dumps on the left side of the dp (passenger side). The tube comes very close to the right fan but it does clear ir. If you have a FMIC then it might not fit.
yes you are correct, it does blow a lot of exhaust onto the crossmember, i am considering taking it to my local muffler shop to have it extended either past it, or maybe even further like a side exit, that would be pretty cool, dumping right beside a mustang, and by right beside, i of course mean way in front:thumb:
Yeah that sounds awsomeLOL but then the thing is that instead of a mustang you find out that it was a copLOL.To make it worse, it so happends that you have a stutter box and you are spitting flames that the cop's car. I wonder what would happendLOLLOL Yeah just take it to a muffler shop and have them extend the pipe and angled it a bit different. Thoes ebay dump o2 housings are very pretty and all. I won't deny it but they suck. At least that was my case.
Yes you are right about that. Most cars are different. I'm just giving my opinion based on first hand actual experience. It is a good o2 dump housing IF you are a 2g or if you are able to modify it. I have the SLS on my car now and the ebay one is laying somewhere in me garage.
Just FYI don't use the bolts that come with the o2 dump. I did and even with lock washers they would loosing up.:mad:
But the fit is good and even with my 3"dump everything clears nicely.
Yeah, i had that problem, but for $1.50 at The hardware store, that was fixed easily
Hey Cuervo, do you have a picture of your engine bay, w/ the dump installed???:talon:
