o2 dump installation problem
ALLeyesONmyGSX
138
Jun 9, 2004
Los Angeles, California
so im removing my stock o2 housing and i open up all the bolts nicely, everything is going great until i try to take the o2 housing off the car, and i realize the dipstick line is in the way . . . there is no way the housing can come off . . . any suggestions . . . ? . . . thanks :dsm:
Take the dipstick tube out. I believe it is a single 14mm bolt. However, I can't verify the size, but I do know that it is only one bolt. Follow the tube, and you'll see the bracket.
yep like he stated above. youll have to take off that bolt wich holds your dip stick to the motor. and then move the dip stick over a lil bit, but before that take out fan itll give you more room to work and when drop in the dump.. I had to cut a piece of bracket around my fan too so that the dump wont hit it. but it all depends on which dump you got.. mynes was from punishment racing.
