o-ringed block mixing oil
lillev23
77
Jul 27, 2006
Albany, Georgia
Here is the deal. I have 6-bolt swap in a 2g. Its fully built and o-ringed (check my profile). The problem is that I check my oil and it looks kind of milky. block and head were resurfaced. I have a mitsu mls on copper o-ring. what do you recommend I do to fix it. Maybe copper spray the HG? I torqued head studs down to arp specs. Any help would be greatly appreciated.
Do you still have the oil/antifreeze heat exchanger on the oil filter housing?
Sometimes, these can fail internally, allowing the oil and coolant to mix.
It's worth looking at before you pull the head, that's for sure. :thumb:
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
