NX Direct Port Install
GILZTSIAWD
748
11
Feb 4, 2004
petal, Mississippi
I was just wondering if anyone that had done this install had pics of it? Just wanting to see if someone had the pics of where/how it was tapped into the manifold so I could get an idea of how I should do mine.
Thanx in advance
Gil
I have no pics sorry, however many people put it under the manifold or on top which is harder. I would probablly say the bottom side of the manifold where ever you can get the nossles to sit properly without being in the way of anything. Only problem is changing jets is a PITA. The stock manifold leaves little room on top for the nossles. The closer to the head the better as they need no real atomization a few inches is enough (since so little runs through for each cylinder) but they can be close to the plenum if you need with no ill effects. The closer to the head the hard the "hit"
