nt to turbo resistor wiring
Blitz_86
165
Sep 26, 2002
savannah, Georgia
im just needing to know what to do with the white wire on the resistor pack? the 4 black ones i got going to the injectors after that im confused? is it a 12v power supply?
i have looked in maviskys nt to turbo thread and alot of the pictures dont work, like the one of the resistor wiring diagram
The common wire is for the power to the resistor pack. Normally it would connect to the MPI circuit rather than run the power directly to each injector like it does on the NT. If you can find the wire to the injectors you just replaced you can connect it to the white.
  • Wanted 6 bolt NT water pipe
    • chrisman287
