nt idling high
whe3ls
910
5
Jun 23, 2008
spokane, Washington
ive been having issues with high idle, it idles close to 1500k to 2k, i dont think its the bliss screw because if i adjust it right at idle in park it idles too low in gear. i un plugged the maf it the idle is the same.
check the rubber boot behind the maf for vac leaks, and also check the maf out . you shouldn't be able to unplug the maf and have it still run the same way.
i re unplugged the maft again today, and the idle droped from 1500 to around 750
