Notchy 93 shifter
crankwalka93
Mar 21, 2006
berlin , Connecticut
When i go through my gears it doesnt grind and goes into gear easily. My tranny is fully rebuilt but it feels as tho my shifter is notchy and is very noisy when I shift gears. I know it isn't hurting anything tranny wise but i was wondering if there was a way to fix it or if its normal. Gear Lube??
-Sorry if this is a repost i looked but I wasnt 100% sure if the other sittuations were the same problem as mine
Might also try some shifter bushings. There are two kinds: shifter base bushings, and the underhood bushings at the ends of the shift cables. I put on the underhood ones and the shifter feels much more firm. Were only $6.50 from a guy on here.
