not remove tint?
Street_Killer
267
Jun 12, 2007
Alberta,
If you plan on installing tint on your car, is it a must to remove the factory tint? Why would you have to?
If the tint is not fadded to bad or peeling you can put tint over it. But if your tint has scratches or nics on it, it would be better to go ahead and peel it. I do tinting and we have alot of people that want theres doubled up to make it darker. ITs not thebest idea but its all up to the customer. On some vehicles the factory tint cant be removed because it made in the glass. But in your case im guessing that your referring to your talon. Which they didnt have factory tint so it has been added. But like i said if the tint isnt bad then you would beable to double it up. But if you want it to last longer i would just redo it all. Because sooner or later the tint that is already on there will start peeling.
  • Wanted 6 bolt NT water pipe
    • chrisman287
