Not firing on cylinders 3 and 4
unlikely hero
273
Feb 2, 2004
Atwater, California
Well trying to start my 2.4 hybrid and misfiring on cylinders 3 and 4. I get spark in both, not sure on fuel or compression but just cranking it ) I can hear whooshing from the breather filter. but don't know what that means. Anyone have any suggestions? Thanks
=Jason-
If you pull the plugs on those cylinders after cranking it, are they wet with fuel?
If so, you need to compression test.
unlikely hero said:
I can hear whooshing from there but don't know what that means. Anyone have any suggestions? Thanks
=Jason-
How about a compression check? It's possible that there is some water in the bock that the W/P is trying to move so it's just sloshing back and forth. Disconnect the W/P belt and see if that makes it go away.
Cheers,
GTM
I meant to say that i could hear it through the breather filter not the water pipe, i'll edit the first post. My question is would this be caused by timing to be off a notch? I plan on doing a compression test tommarrow.
=Jason-
=Jason-
We can talk this to death, a compression check is 10 minutes out of your life. Checking the timing is another 10 minutes. I don't know if it's telling you something but either of the above tests will.
Cheers,
GTM
    • Sdcryan1
