Noob Taillight Question
Amazin' Wasian
Banned Member
476
4
May 7, 2004
Tulsa, Oklahoma
ok on the center peice of the 2g eclipses how do u get the silver letters that say eclipse off?? or do i have to order a new peice? :dsm:
you could probably use some kind of glue thinner and something flat like a razorblade and they should come off
I used a blow dryer (should use a heat gun it would have been A LOT faster) and heated the leters up. Then you just peel them away with your fingers, after that I used tar and bug remover to remove the access glue. I then windexed the center light and it looked gorgeous. If your taillights are old enough you will still be able to see "eclipse" because the other parts of the light faded faster than The part under the sticker that wasn't exposed to the light.
