Noise when going 45 mph???
svave
104
Sep 10, 2002
I get some kind of weird noice from the rear left when I go about 42-48 mph. When I go in other speeds I cant hear anything. Its like a swooshing noice and its driving me crazy. I have checked everything but without result. Also had a friend drive next to me to see, no result.
Anyone know or had the same problem what it might be?
Please let me know.
Thanks
I got the same problem and it sounds like a rubbing sound going at 45ish mph and I still dont know what it is. It could be the axles i think.
Have you/anyone else used any type of flat repair techniques that are injected into the tire? Such as fix-a-flat ?
If so this can coat the tire and then the remainder and turn into a water in which will "slosh" around and cause a vibration and a rough time for the alignment shop. :nono:
Have you tried messing with the E-brake? BTW, I'm not suggesting that you travel at 40+ mph and yank your E-brake. (< Liability reasons )
If you take the car out of gear at that speed will it still make the noise? Or will it only make that noise when the car is in gear?
