Noise on Decelleration, please advise...
jfdid
267
Dec 18, 2003
Calgary,
I just had the car up on jacks to change some tranny fluid and tighten my downpipe. When I got it down, and went for a mild drive, I'm getting a very odd clunking/vibrating/thumping noise coming from somewhere from my seat and forward.
I've gone through the obvious things, I could use a new wheel bearing, and a new rear U-Joint, but I doubt those are the problems. I'm not a newbie, just trust me, it's not the bearing, and there's a slight chance it's the u-joint.
What are the chances of my pressure plate bolts backing off? I used LocTite and torque to spec. I've run the car since a motor rebuild for 15,000 miles now. Any ideas on this?
The noise shows up primarily when I accelerate, and let off, with my car in gear, clutch out. The noise is faster than the frequency of my wheels turning, so I highly doubt it's the wheel bearing and the CV shafts.
In first and second gear, does the driveshaft(for awd) move faster than the wheels or slower. I'm sure it's faster, but I'd just like to have a concrete answer.
Thanks for ANY input guys.
I would think that you would see problems WAY before 15K miles on the clutch. All axles rotate the same speed as the wheels. The DS on the other hand rotates quite a bit faster than the wheels in all gears.
Don't you 1G guys have issues with a DS bearing or something? Here: http://www.plymouthlaser.com/shaft.htm
Omega, thanks for the reply. The problem turned out to be my exhaust. It was slightly banging against the underside of my body. Weird though, wouldn't have guessed that it would make a sound like THAT.
Anyways, thanks again.
