No Vacuum in FPR Hose
93talonlunatic
Jun 18, 2003
Tecumseh,
Ok, today my car went right to 140% on the logger so i checked the fpr, took the vacuum line off and noticed it has no vacuum at all. Now the car stays very lean no matter what I do to the FPR or the SAFC2. What would cause this line to loose vacuum?
Thanks In Advance
trace the vacuum line back to the source even blow through the hoses if you have too, and with no vacuum on the frp it dosent let any fuel go through the return line also not letting the fuel system relieve an pressure, if the fuel system is a return type
