no start. need help
DSM nOOb
511
5
May 17, 2006
Columbus, Ohio
Ok so here's the setup. 2g 6bolt swap fic 950's with v3 lite I have the global and deadtime adjusted correct for start up 272's 255hp with aeromotive afpr fuel pressure is stock. I have the use a non 95/96 sensor box checked.
I try to start the car it cranks and cranks the car will try to fire itll kick but it wont run. The idle switch does work if that matters. Compression is good. Any ideas?
EDIT RESOLVED: i forgot to switch the plug wires.
