No spark help
iforgotmyname
83
Mar 2, 2011
Wahiawa, Hawaii
Hey guys i know my car has a bad fuel pump because im not getting any fuel spray from my injectors but i'm also not getting any kind of spark... ive changed plugs and stuck a multimeter to the plug cables im getting the right kinda power just no spark...:banghead:.... anyone think of anything for me to check or try...
Have you checked all of your fuses and relays? Have you tried hot wiring the fuel pump to see if you get pressure? I know this thread is about spark, but I'm still curious. You said you're getting all the right kind of power, what does that mean?
I had a similar problem, you should look at my posting (go into my profile look up posts). Injectors wouldn't spray. You should double check to make sure that your fuel pump is bad, because chances are it isn't. Just because the fuel injectors aren't spraying doesn't mean that you aren't getting fuel to the rail. It ended up being a bad cam position sensor (under the intake manifold cam gear). Hopefully that helps.
