no power to tps
maddog_187
89
Mar 11, 2006
Grand Junction, Colorado
Okay need help again!! Where does the tps get power from? Is it the Ecu or from another power source? I'm getting a no power to the tps! The reason i'm curious about the ecu is I was sent a 91 and was told it was a 90 so ran it a month before I found out so the pins to the ecu were not switched. So could my ecu be bad now and causing this or is there somewhere else I should be looking?
Thanks in advance
It is giving me a cel 14 code. I've replaced the tps with a used one off ebay. I checked it out its okay but getting no 5v power to the tps
well you got 5v going to it from where not sure then it sends back power to the ecu depending on the amount going back changes ecu will make the changes. I believe this is correct. but it needs power going to it (5v) before it can send power to the ecu. which is how you adjust it the power going back to the ecu should be .48-.52.
Well looks like the computer is the problem! I got capacitor's leaking. So I will change that unless any one has another idea?
Got my old computer in and not tps cel!!! Now all I have to worry about is fuel cut!:notgood: Does any one know how a maft will do with fuel cut? Does it tell the computer everything is good and i have enough fuel to cover the boost? Any oppinions or ideas let me know
Thanks
