No power to ECU...what could it be?
I LOVE AWD
Jun 3, 2004
Bala Cynwyd, Pennsylvania
My ecu has NO power to it....is there a fuse or something???? i need to be able to fix it asap
thanks!
I'd take a multi-meter and hunt down where your losing power..First check at the ECU..if your getting power to the ecu, but the ecu isn't working correctly..then you know..you've got a problem with your ecu...if that's the case..Check or replace your caps...Good luck!!
