what could it be????
yunior
99
May 13, 2005
jacksonville, Florida
OK guys I'm back finally installed my gauges and my boost controller changed my sparkplugs to ngk bpr7es and properly gapped them between .7-.8 mm when I changed the spark plugs the stuttering seemed to stop but my greddy e01 (boost controller) and my boost control gauge have a reading of -7.5 psi when I turn on the car, when I get on it the most it goes up to is 10 psi and in normal driving its about -6.5 unless I'm accelerating, I have the stock settings on my SAFCII, and no adjustments have been made to the boost controller (meaning have not increased the boost on it) I have not done a boost leak test due to all the rain in fl now but would like to know what could be causing this problem how to fix what should I check for or any input that would assist me with the issue I'm having any input would be greatly appreciated thanks :dsm: :( :cry: :confused: WTF
v2ner said:
that's the vacuum. it's normal.
It is not quite normal, that is a pretty low vacuum 6.5-7.5 psi. It should be near 16. Check your vacuum lines. Do you have the vacuum lines hooked up right?
-Joey
Vacuum is measured in in/Hg, not psi. But I agree, that does seem low for idle and cruising. Where did you tap in for the gauge?
i have a greddy unit and the vac only reads to 9.9
if you are in the 6 or 7 range you might have a leak or the line might be tweaked also.
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
  • Wanted 1g Fuel Pump Hanger Assembly, MPI Relay
    Current one is rounded off, kinked and crusty. Looking for a good condition 1G AWD hanger and a...
    • Gabe92RTTT
