No power on cold start and low boost, popping noise and gauge jumps
Revdoc
Feb 3, 2004
Columbia, Missouri
This has just recently started happening to my 91 Eclipse GSX automatic. It is completely stock other than the addition of a boost gauge, and I redid all the vacuum lines and removed the EGR.
I start the car in the morning and drive about a mile before I get on the on ramp to the highway. I usually baby it because it's cold, however when I go to get on the highway I have to give it some throttle to get up to 60-65 before the end of the ramp. This is where the problem happens, I will slowly increase throttle to maybe 20-25% and I can watch my aftermarket boost gauge increase to about 5 psi, but I don't get the increase in power that I usually feel at 5 psi. I hold the throttle steady and the car makes a hollow popping noise from up front, at the same time the boost gauge jumps, but it's so quick I can't tell if it's dropping to 0 psi or what. The noise happens once every 2-3 seconds, when this happens I usually give it more throttle and it boosts up to 10 psi and gains power and runs correctly. I have noticed that the stock boost gauge on the tach reads steadily when the noise happens and the aftermarket gauge jumps.
Once the car is warmed up the problem seems to go away. There is a smooth transition into boost and it pulls fine at low throttle, low boost conditions. I have had loose intercooler hoses before and it would boost to 5 psi or more and then the boost would blow out through the loose connection, the current problem does not sound the same, plus I can hold 10-12 psi just fine if I give it more throttle so it can't be a loose hose. I am going to double check vacuum lines today and I will have a data logger before too long, so hopefully that will help with the diagnosis. Any ideas? I have searched and found threads about phantom knock and crankwalk, I don't think it's crankwalk because I have a 1G, I don't think it's phantom knock because it seems to affect the boost gauge.
Alright, I pulled the manifold and turbo off today and found some good evidence of a problem. The #1 cylinder was wet and black, looked like fuel. See the attached pics. I will be getting new plugs tomorrow, I changed the wires already a couple of weeks ago. So it seems this is the cause of the car running like crap when it's cold, it's not hitting all 4 cylinders. I know it runs on all 4 when it's warm because it is a night and day difference. So what could cause the car to misfire when cold? Coil pack? ECU? Any tests you would recommend?
Today I figured out the problem. I pulled the spark plug on the #1 cylinder while it was idling and the idle didn't change. It did spark from the end of the boot to the valve cover, so I assumed the coil pack and wire was okay. I pulled the fuel rail and swapped the #1 and #2 injectors. Then I started the car again and pulled the #1 plug wire. The car almost died. I put it back and pulled the #2 wire, no change in idle. So the problem followed the injector, I guess the injector is sticking open and flooding the cylinder when until it warms up. I assume it was sticking open because the cylinder was wet and I usually smell gas when it's running like this. Either way, I have a set of 450cc injectors on the way and I will swap them out when I get them, hopefully that will remedy my problem. I will update the thread when that happens if it does indeed fix things.
