No power Help Please
RICKYTURBO
Jun 6, 2003
YABUCOA, Central America
:dsm: hi there:
this is my problem.. yesterday I started the engine and the engine lose the power and dead after that the car has no power, only interior lights, no power window, no starter, no cluster no nothing, I already check the fuses with no luck can somebody can help me out?
I doubt it, but if you have an Advance Auto Parts in your area (I know you are in Central America) or an auto parts store like it and have them test your battery and see if the battery will hold a charge. If not, your battery is bad. If the battery does hold a charge, then there is a good bet that your alternator is dead. A local auto parts store may be able to test the alternator as well.
RICKYTURBO said:
the battery is good. can somebody has a clue?
Did you not read the comment about the alternator probably being bad?
"If the battery does hold a charge, then there is a good bet that your alternator is dead. A local auto parts store may be able to test the alternator as well."
On the Pass. side under the hood their is a fuse/relay box(the big one). When you take off the cover their is a black 90 fuse sitting in the bottom right corner. If it is bad then your car won't start, your radio, seatbelts, windows, etc won't work. Check it out. That particular one usually blows if you mess with your alt. with the battery still connected. Hope this helps.
