no power after 3 thousand rpms
eclipsegsx6165
Sep 4, 2006
Terrytown, Louisiana
i drive a 98 eclipse gsx and recently i was driving home and my car goes into gear but after three grand it doesnt have any power and it just goes through the rpms really fast someone please help
That has got to be your clutch. Is your pedal adjusted properly? Wondering if you've extended the rod from the pedal into the master cyclinder too much to where you're pre-loading the clutch system.
Clutch!!!! Do you have a boost gauge?? If so what PSI? If not go get one!!! The stock one is lame. But if you are hitting boost is most likely your clutch. Maybe the shop that installed it messed it up. It happened to me, Twice!
yeah i have an after market boost gauge and im running stock boost on a stock setup the only thing that has been altered is a front mount intercooler an intake exhaust and the clutch upgrade that were mentioned before in this thread
Definitely sounds like your clutch. If you've been slipping it for too long you've probably glazed your flywheel. Do you have plenty of clutch fluid? I had someone install a clutch for me before and he didn't tighten the clutch slave cylinder enough. I leaked most of my fluid and glazed my flywheel pretty quick.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
