No oil getting to head?
John Mark Dongon
5+ Year Contributor
94
5
Feb 7, 2019
Stoccton, California
I'm trying to prime my rebuilt engine but there isn't any oil getting to the lifters when I spin the oil sprocket with a drill. Has brand new 3g lifter I bleed them out before install, oil pump was reconditioned and did a balance shaft delete. I filled the engine with only 3.5 quarts is that enough to reach the oil strainer or do I need to put more oil?
Have you put anything in the pump to prime it, like assembly lube or some Vaseline/grease? It'll be hard for a dry pump to pull up oil.
Otherwise you may have a big air leak somewhere.
Figured out that was the problem! I put some petroleum jelly and now oils getting to the head! I didn't think lube would fix it, but your right!
Did you by chance inspect the shaft and gears, since they were run for a while with a low weight lubricant? Hate to have the oil pump take a crap from galling or scoring.
and all inside surfaces of the pump as aluminium is softer than steel..
@BLACK'98DSM nobody's arguing, I felt I needed reassurance I was being tricked by a perspective distortion haha. I thought I was going crazy but it makes sense when one looks at the centre round part of that gear
