2G No injector pulse on cylinder 2
Check to see if the is a pulse at the resistor pack on the firewall. You may have a dead resistor. I have a spare pack if that is the case.
Edit: The resistor pack delivers a pulse to two injectors at a time so if it were at fault you would have that condition on both injectors.
Is there pulse available to the injector plug? If so, then test the injector itself. I think you would be looking for 13-14 ohms.
On a 4g63T 2.0L there's one resistor for each injector each connected to a unique ECU pin. So why do you say "The resistor pack delivers a pulse to two injectors at a time"?
Also each stock turbo injector is 2-3 ohms, not 13-14.
SO i been working on the 97 all stock awd talon except 99 ecu which is not the problem but here goes nothing ... so i have an injector thats not firing
i swapped plugs from one working cylinder to the cylinder thats not firing and found out its not the injector but all injectors except 1 injector clip is not working which i think is number 2 cylinder but i can find out a way to for sure test this and what is causing this to happen ...anybody have any suggestions?:hmm::hmm::hmm::hmm::hmm::hmm:
Are you getting voltage on the suspected injector? Using a noid light is best but even a multimeter will show a different reading on bad injector circuit (compare to others). Note: Voltage is high most of the time but drops down during the pulse. If no voltage, check the injector resistors - should be 5.5-6.5 ohms each.
