No Idea
mat4ram
30
Oct 6, 2002
pell city, Alabama
ok, my cars trans has been acting up the past few weeks and im not sure what else to do. when you accelerate most of the time its shifts from 1st to 2nd but when it goes to shift to 3rd it just kind of revs alittle and feels like its going to shift but it never will unless you get on it alot. i just replaced the trans ecu, trans solenoids, trans fluid, and trans filter but the problem continues. the trans was supposedly rebuilt about 15,xxx miles ago but the shop wont warrenty it because it was a 6 month warrenty which was about a 1 year and half ago, but it has been sitting because of motor problems. im just out of ideas. any help is needed. thanks.
It sounds like your trans may be bad again and might need to be rebuilt or replaced.
-John
Originally posted by mat4ram
any idea what would be the cheapest way to go? i dont mean cheap but i dont really have any money...dsm's get expensive
The cheapest way is usually to fix it right so you only need to spend the money once.
-John
Somebody just told me that transdude, CRY ONCE. That means cry over the price you paid the first time to get it done right, instead of the "cheaper" route and something that might not last, or work. I found that out the hard way, I have over 1k invested in a trans that still doesn't work because I went with a "used" trans replacement, this and that. So my advice to you is spend the $2300 to have it rebuilt right. I think you can shave a couple hundred off if you pull the trans out yourself. I can help you there, and it can be done in a garage with minimul tools...
Sounds like you got good advise, unfortunately you got it too late. It sucks to spend money for the same thing twice.
-John
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
