Lofty
- 4,250
- 44
- Jul 27, 2008
Waukesha,
Wisconsin
I don't have headlights on my car.
I jumped the relay, the headlights DO infact work. So it's not wiring from fusebox to headlights. BUT the relay is only receiving 8 volts, which isn't enough to make it pick over. So. I have a bit of a wiring mess under the dash. I had indiglo gauges and some ricer narrowband and shit. Everything works fine. The headlights did infact work for a while, but then they started to work intermittently, then stopped all together. So what is this? The stalk switch going bad? Bad ground? Wiring? If anyone can help rep will be given.
